I’m also open to ecu flash if that’s even really an option or viable. Just looking to liven her up a little around town.
Start reducing that weight. Depends on how much you are willing to spend and if this is a daily driver or not. Remove the spare tire (31.2lbs) and jack (haven't weighed that yet). Pull the plate out of the glove box that people say weighs 5lbs (haven't pulled it out yet). If you have some money, buy the JDM bumper beams while they are still available ($100 each) (56.4lbs weight save together). Start working off some of the Covid 19lbs you put on from being home (I've gained 40 not good lbs since buying my car almost 15 years ago lolz). CD player (2.8lbs). OEM Subwoofer which probably doesn't work anymore (4lbs). Antennae delete (1lb). Put the OEM 16's back on it since you probably aren't going to find anything lighter that isn't forged. If you are getting new wheels, make sure you are losing weight. Tell your buddies or significant other that they need to be under a certain weight or you are buying the airbag delete for the passenger side to help compensate for their weight (joke).Yea that’s the plan in about a year as budget doesn’t permit a swap currently. Was just curious if there’s anything to just liven it up I’m not looking to make high hp by any means. I will check out the other posts to see if they don’t say anything as well.
your best option as budget wise would be just putting a turbo on it, and sending it till you can afford a swap. Did it with my build.Yea that’s the plan in about a year as budget doesn’t permit a swap currently. Was just curious if there’s anything to just liven it up I’m not looking to make high hp by any means. I will check out the other posts to see if they don’t say anything as well.
I know you said your rpm’s where smoother would you say there was any power difference just wondering I have been looking a little into delicios tuner but I didn’t really see if it said any power gains? Haven’t dug to deep but just wanted to hear your opinionI have a 2000 RS n/a and have a older Delicious Tune reflash... which at the time was a "stage 4 tune" in his newer offerings it would be a "stage 3".
I noticed a big difference on how my build was running and it was a lot smoother going thru the RPMs. Delicious now offers WiFi tuning with our generation of ECUs. Its one of the only options I've found in the 19+ years I've own my RS. You can always go full stand alone ECU but finding someone to set it up and tune it would be pretty expensive. Delicious Tuning is going to be your best bet budget wise I feel.
I'm not a builder or a tuner I work on my own stuff and I kept my car alive all these years.
~~~>>>>Delicious Tuning <<<<~~~~~
-Justin
My dude, right here on the product page, breaks it down what mods are applicable and the power increases that can be expected by all four tunes they offer...I know you said your rpm’s where smoother would you say there was any power difference just wondering I have been looking a little into delicios tuner but I didn’t really see if it said any power gains? Haven’t dug to deep but just wanted to hear your opinion
