1 - 20 of 63 Posts
RSTI PANDA
So after Breaking my engine NA, i will go turbo since i need to buy pistons any way.
so i got a heads up on some good deals and got every thing on the list for a good price.
Here is what I have so far.
-STi Pistons
-STi Piston Rings
-STi Rods
-STi Oil Pump
-STI Bearings Rods,Piston and Crack shaft
-STi Radiator cap
-Cosworth bearings
-ACT 50/50 Clutch in the car already
-Exedy pressure plate
-t03/t04 turbo
-Innovate wideband
-custom up and down pipe
-STI Top Mount
-Walbro 255
-850cc injectors
-Emange Ultimated whit pressure sensor
-Tial Waist Gate 38mm
-Boost, EGT, Oil pressure guages
-Light weight pulleys
-Bosch Platinum fusion spark plugs
-heads have been taken to the machine shop, for acid wash and gasket change
-Full Gasket set
-Motul Oil
So far on all that on that list i spend $1358.75:):sunny::naughty:
Guys plz let me know if i should change something els
Im not yet sure if i should buy a oil catch can?
Let me know what you guys think
Thanks
2000 Impreza Sedan
looks like my shopping list on my last turbo build! keep us posted:
-stainless lines? (always a plus but a bit pricey)
-I would suggest Denso BRE7's for plugs if you are going to run higher boost
-wideband is also a good to have (especially with after-market turbos)
just my 2 cents
05 rs 04 wrx 05 sti all black
Well after this is built it should have the same durablity of a sti engine. I would think you would want to run somewhere in between 15-18lbs of boost. Could go up to 21 but I think that could be pushing it.
02 F-150 Extended Cab
what kinda turbo r u plannin on using..boost is a relative term.
stock sti blocks have been known to hold 500 whp..and can do 400 safely.
isnt that one of those huge turbos??
id just start with 10 lbs, you'd really have to consult with a knowledgeable engine builder as to what afr's are safe under boost, what ring gaps to run, etc
2001 Impreza OBS
11-11.5 for AFR's and as far as ring gaps... he wont have to set any. They come factory set since his pistons are take outs. Boost wise.. i run 23-25psi on 93 pump. Now, keep in mind i have a full standalone ECU. So, i have total control over ignition timing and AFR.
Seems you have gotten things for fairly cheap so far.. i would spend the extra money and buy a good EMS and have ultimate reliability. either a AEM EMS, or Hydra.
1998 Black Swapped RS
Where are you finding these parts if you don't mind sharing? I am having troubles finding good sites to order the STi internals to do a rebuild.
say if he were to run 10.5 afr's or a tad leaner would it have any negible effects?
2000 2.5RS
tipo cm stas es el bro de mariana cndo lo acabes me dejas saber cm te fue pa q me ayudes un poco pq el mio viene soon y necesito ayuda jaja te cuidas bro
RSTI PANDA
Discussion Starter · #20 ·
pues claro mano, cuando salga sabes que la ride esta ahi de gratis jajaja
me avisas cual quier cosa
1 - 20 of 63 Posts
