dsniner-
My name is Matt and I am the one who personally worked on your manifold. I just want to get a couple points across, they are more or less informational when it comes to porting and polishing but none the less. I am sorry that you where told that your intake manifold would be gasket matched, this should only be done in a very few certian instances. A.) if the intake side of your heads were ported to match the gasket already. B.) if the existing OEM intake port profile is larger than the OEM gasket which is not common and I cannot think of any instances off hand where this applies.
The reason we or any porter for that matter would most likely not do this is because you increase the step that the intake charge is hitting as it enters the head. That would create more turbulence in that area. In a perfect world the intake, gasket, and head port profile will match up as perfect as possible, but this can only be acheived through headwork aswell.
As far as what was ported on your manifold, we can only do line of site porting, so 90% of what you can see I would say can be reached. Due to the tools we use and the diamiter of the tool used this will restric us in a very few limited places. I assure you the tools I use are not a kit from summit racing. I would describe more but there are certian things we use that maybe not every other shop uses.
As far as the center of the manifold, there have not been any signifigant gains from porting this area. As far as the cleaning aspec of the manifold I appologize for that, I personally do not clean the manifolds but i know we will be taking every step possible to return the item to you as clean as possible.
A couple informational things quickly, to port the manifold completely throughout, the manifold would have to be cut and welded. At that point the costs would skyrocket and you would want to look at purchasing a box/mandrel style manifold. Trust me I wish I had a little porting gnome I could send inside to reach the areas our tools cannot. Also while on the topic I just finished a customers manifold and I DID gasket match since the customer specified that they have had head work done and the head intake ports where matched to the OEM gasket. Feel free to contact us and if you would personally like to speak with me I would be more than happy to answer any questions I have not so far.
Sorry for the poor grammar and run on sentences.
