**NEW PICS**
POST 47
I bought this car April of '07 after selling my '05 STi with the idea of building something just as fast/fun but for less money and cheaper on insurance. Its been just about a year later and shes almost ready to come back out. No its not swapped just yet but all in due time.....
Mod List
Suspenion
Whiteline ALK
Whiteline 22mm N/A Front Sway Bar
Whiteline 24mm WRX Rear Sway Bar
Whiteline Heavy Duty Rear Sway Mounts
Whiteline Front & Rear Sway Bar Endlinks
Whiteline Lateral Links
Whiteline Rear Strut Tower Bar
Whiteline Front Roll Center Adj Kit
Whiteline Rear Toe Lock Out Kit
Rota Boost 17x8 +48
Tein Front Strut Bar
ARP Extended Wheel Studs all around
'05 STi Brake Booster & MC
Wilwood 6/4 Pot Brake Kit
STi Group N Rear Crossmember Bushings
ATE Super Blue Brake Fluid
New Ebrake Pads
STi Lower Control Arm
Super Pro GC Lower Control Arm Bushing
Super Pro Front & Rear Trailing Arm Bushing
New OEM Hardware
BC Racing Coilovers
OEM Rack & Pinion
Hankook K104's 245/40/17
MRT Master Cylinder Brace
Drivetrain
Techna-Fit SS Clutch Line
Super Pro Rear Diff Support Bushings
Super Pro Rear Diff Bushings
Kartboy Trans Crossmember Bushings
Drive Shaft Shop Alum Drive Shaft
ACT Heavy Duty Clutch Kit
Fidanza Flywheel
Cusco Motor/ Trans Mount Kit
Kartboy Short Shifter
Kartboy Front & Rear Shifter Bushings
TIC Shift Linkage Update
TIC Shifter Pivot Bushing
Ixiz Concept Race Pitch Stop
OEM Clutch Slave
New Axels all around
Engine
STi Radiator Cap
Kartboy Battery Tie Down
New gaskets, pumps, belts, seals on the "new" RS motor
Perrin Crank Pulley
Borla Headers
Kartboy Exhaust Hangers
AEM Intake
Braille Battery
'08 Subaru Magnetic Oil Drain Plug
OEM Battery Cable
Stromung Cat-Back
Walbro Fuel Pump
Splash Sports Steering Hub
Sparco Steering Wheel (Off my old 240sx)
WRX Pedals
STi Spec C Shift Knob
Shifter extender
Wingless Trunk
Subaru License Plate Bracket
Osram Headlight Bulbs
McColluch HID's in the Fog Lights
EBay STi Fog Light Covers
JDM Tail & Corner Lights
EBay Clear Side Markers
Tein Hood Dampers
POST 47
Mod List
Suspenion
Whiteline ALK
Rota Boost 17x8 +48
New Ebrake Pads
New OEM Hardware
BC Racing Coilovers
OEM Rack & Pinion
Drivetrain
Fidanza Flywheel
OEM Clutch Slave
Engine
STi Radiator Cap
Perrin Crank Pulley
Borla Headers
AEM Intake
Braille Battery
OEM Battery Cable
Stromung Cat-Back
Walbro Fuel Pump
WRX Pedals
Shifter extender
Wingless Trunk
Tein Hood Dampers
