1 - 9 of 9 Posts
ok, i feel lame for asking, but i figured i'd rather be safe than sorry.
so i got my car back from the bodyshop friday. i noticed that the hood vents aren't all the way back into their slots. there's one tab on each side that's still sticking out... do i just force it back in, or is there a trick to it? can it break or scratch or anything?
00 RS, 14 Forester, 92 SVX
They put them back in without putting the tabs underneath the metal edge. Happened to me when I put my vents back in the other day ;). You'll have to remove them completely to put them back in properly.
Discussion Starter #4
BrightonGC8 said:
check the mounting screws
ok, so they're just screwed on? i can just unscrew them and pop em back in?
Nuts on studs actually- 8mm IIRC, but yep- pull the nuts off, lower the shields (if there) and push them up and out of the hood. You'll see the tabs causing the trouble once you do.
'99 2.5 RS Rally Blue Pearl
haha, i was going to say it's 5/16ths :)
one of my bolts is being really annoying. i want to take the vent cover off, but when you turn the nut the bolt turns as well, so it doesn't unthread, any ideas on how to solve it? :(
hmm, keeps twisting out of my grasp...ohh well, i'll just keep trying :)
Use vice grips, just not on the threaded portion do it on the part of the shaft after the threads. I have done it many times at my metal fab job, works like a charm.
1 - 9 of 9 Posts
