1995 1.8L Impreza Coupe
I spent the better part of today trying to find the answer to whether or not we can swap multifunction switches between years or not.
Essentially, I have a '95 and one of the previous owners of my vehicle cut the horn and airbag wires when they swapped from a stock steering wheel to a quick release setup. I would like to swap the multifunction switch to repair the cut wires, ideally with one of a '98+ so that it can have the (more) adjustable windshield wiper speeds. Are they all compatible with one another? Do the plugs from an early '95 work with one from a later year GC? The only information I can find is for swapping the entire steering column (which I'm trying to avoid). Any help would be appreciated.
Anything wiring related I would ask iWire. They can probably tell you everything you need to know. Having recently done my dash harness, the steering column electronics are not that difficult to deal with.
'95 GF6
I believe 1998+ switches do not come with a pigtail like 1995 does, but have a newer style plug molded into the housing. Anyway, if you want adjustable wiper speed, there is a switch from LS/LSi Legacy models of the same vintage that will plug in. Sorry I don't remember the p/n (sold the car in 2017; came upon this thread because it was "trending"), but I posted the information on NASIOC. There is a comprehensive thread covering the wiper switch swap. You can even get a switch specified for a wagon and add JDM rear wiper to the coupe if you can find the parts, but that would be quite a project.
