1 - 9 of 9 Posts
07 wrx
ok i found a sti motor for sale. what im asking is if anyone has swaped or thought about swaping? if so could you guys could give all the info cause about really really close to swaping one. thank you guys again.
MY00 Subaru Impreza 2.5RS BRP
do a search here and i-club. someone from i-club (chris something) does it a lot. I think it's i-speed. I am not sure. check it out!
yea, i-speed did a couple of swaps, but from what i know, i think all their swaps are with USDM EJ20. i don't know if there is any different between USDM EJ20 vs. JDM EJ20. and btw, what tranny you planning on using? if it's a STi motor, then that son of a bitch got lots of torque.
jz
07 wrx
Discussion Starter #4
it comes with the sti trans mabey ill be the frist to do this swap!!:biggest:
05 LGT limited
dsmawd in Lansing has done the swap... maybe pm him on i-club
pics would be cool. but all it'll do is...make me :drool:
jz
2006 BP5 Satin White
What car are you doing this swap on? I've been
working on a JDM 2.0 turbo swap into a GF body.
It's not an STi engine, but I scored three MY01 short blocks
earlier this year for very close to nothing. I'm building one up now to go in the Impreza. I may build the other one and stick it in my Legacy sedan.
So far I've got STi Ver. VI heads and cams, the Type RA Spec C Engine ECU, rear diff, center diff. Still need a bunch of other stuff,
and it definitely isn't a cheap project.
1 - 9 of 9 Posts
