1 - 3 of 3 Posts
98 impreza coupe, 03 WRX wagon
Okay, so we don't really wanna use the stock engine/tranny mounts on the bug eye project, and I remember seeing the megan mounts for sale a while back. I found the listing, and it said it was for the 6mt only.... I can only imagine that the motor mounts are the same, but is there any difference regarding the pitch stop and rear tranny mount from the 5mt to the 6mt? Id rather not spend $183 on mounts that wont fit.. About to look into groupN and whiteline to see what they have available for the car that we need as well.
I ❤ BOOBIES
99 Coupe
Theyre all the same, 6mt transmission bushing are just a little stiffer due to more weight, thats about it.
1999 2.5RS, 2013 Legacy 3.6R
Motor mounts are all the same.
The Group N part numbers are D1010FE110, D1010FE120.
The Pitch Stops are all the same.
The Group N part number is D1040FE000.
The transmission mounts are different between the 6 and 5 speed. The 6 speed is not as tall as the 5 speed(due to the bulk of the 6 speed case), and while technically the 6 speed could work in the 5 speed, you may potentially throw off the angle of the transmission.
The Group N part numbers are:
5 speed D1010FE020.
6 speed
D1010FE000.
If you're changing all those, replace the transmission crossmember bushings as well.
1 - 3 of 3 Posts
