Whelp I seem to be running into all kinds of trouble with this thing, I love it - it hates me.
I was on the highway Monday morning and cruising about 45, out of no where the car stalled either as I was shifting into 5th or right before I hit the clutch. Tried starting it back up while coasting and no luck so I had it towed home.
I had the battery charged and tested and it's fine.
Timing belt was replaced less than 15k miles ago.
I just put new spark plugs in and have spark.
An hour ago I did a fuel pressure test which bounced between 40-45psi when cranking. Gas Tank is 1/2 full right now as well.
All I have left to check is compression, right? Or should I test the fuel injectors? If I have spark does that rule out coil pack and timing?
I had originally thought it to be filter/pump but don't see how it would be if i'm getting o.k pressure?
The only things i've done to the car since I had a clutch, head gasket, timing belt and water pump put in was replacing a corroded clutch line with a z1 SS line. However at that time I knocked out a coolant hose from the engine to the firewall for a second but got it right back in. I highly doubt that has anything to do with it but mentioning it just to be safe. Also to be safe, the only other things that have seemed wrong with my car is hesitation at 3.8k-4.1k rpm and my headunit randomly turning off.
Really hope someone can shed light on this, I don't know what to do and have spent all day trying to research this.
