I have 1995 JDM Impreza WRX with 107k miles. The leak happens when im stopped and overnight there will be a spot the size of a sand dollar underneath where the rock guard and o2 sensor are. Upon inspecting both underneath and above it appears to be leaking behind the Power steering pump, there is a very small puddle of oil behind it to the left of the EJ20 emblem. The leak is running down the front of my timing belt housing and in the back on the rock guard. There is also a thick oil residue on my tubes underneath the intake manifold behind the PS pump. My valve cover gaskets are both dry and I inspected the PCV valve and it is also dry and functioning. My oil levels are normal and have not changed, the same goes for my PS fluid. I have no other symptoms than the leak. I know the area of the leak, but I have no idea what exact seal or part is the culprit yet. I know the oil pump and PS pump are known to leak later down the road in mileage could one of these be the issue?
-I will also be posting more specific photos later when I have time to get to them.
