Okay guys,
As some of you probably already know I was having some overheating issues due to a bad head gasket and I had a misfire on cylinder 2 that I thought was probably being caused by bad head gaskets as well.
I pulled my motor over the weekend and put in new Subaru OEM gaskets.
I am no longer having overheating issues
I do still however get a misfire code. When I had the head off that cylinder was all brown and i figured it must have just been because of coolant leaking into it and burning in there (causing my loss of coolant and misfire code)
Well... I still getting a misfire code. I swapped my plugs around. I swapped my wires around. I swapped my injectors around. What could possibly be causing my misfire? The car doesn't seem to bog or run rough...it actually feels like it is running very smooth.
I have a brand new front OEM O2 sensor and a used but good rear 02 sensor out of a 99 (mine is an 01) So the difference is that my OEM one had a signal ground wire and the 99 doesn't, but the connector is the same just missing one wire.
Help me please. If there is any more info you need just let me know and I will do my best to provide it for you.
