1 - 12 of 12 Posts
Hi. I'm Mach V Dan. At the invitation of moderator @mike-tracy, I am duplicating my wheel spec thread from NASIOC. I intend for this thread to be a comprehensive database of Subaru OEM (original equipment manufacturer) wheels. I give as much info as I can about each wheel, and a picture of each.
Please keep this thread to wheel specifications ONLY. Please do NOT ask or answer questions here about what wheels fit on what cars, or what's the best wheel for your car. Ask those in another thread, or start your own thread.
If you have solid information about any of these wheels, please post and I'll update the entries as needed. Ideally, I'd like to see wheel weights derived from an actual wheel sitting on a calibrated scale. (That means something like a shipping scale, not a home bathroom scale.) In the absence of that, we'll take what we can get.
All wheels are CAST aluminum unless otherwise noted. All are 56.1mm centerbore. (I don't plan to list Subaru SVX wheels here, but they are 57.1mm centerbore.) Also, all 18" STI wheels will fit both four-piston and six-piston STI Brembo brakes, but the 2018 19" STI wheels will not fit over four-piston STI Brembos. If not otherwise noted, wheels do NOT clear Brembos. Model years shown are my best attempt at showing the FIRST model year the wheel appeared, not EVERY year they appeared.
Please feel free to post additional information here. I'll list everything back to the GC-chassis wheels if we can get all the info together.
In rough chronological order:
98-99 Impreza 2.5RS
Offset: +53
Bolt pattern: 5x100
Wheel Weight: 16.5 lbs
OEM-equipped tire size: 205/55R16
Notes: Clears FHI (red) four-pots
2000-01 Impreza 2.5RS
Offset: +53
Bolt pattern: 5x100
Wheel Weight: 16 lbs
2002-04 Impreza
Offset: +55
Bolt pattern: 5x100
2002-04 WRX
Offset: +53
Bolt pattern: 5x100
Saab 9-2X Aero 16" wheel
Offset: +53
Bolt pattern: 5x100
Wheel Weight: 16.5 pounds (verify)
Saab 9-2X Aero 17" wheel
Offset: +55
Bolt pattern: 5x100
Wheel Weight: ? pounds (need weight)
OEM-equipped tire size: 215/45R17
2002-04 WRX BBS option
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 15 lbs. (forged)
JDM/EDM 2004 WRX
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 19 lbs
OEM-equipped tire size: 225/45R17?
2005 WRX
Offset: +55
Bolt pattern: 5x100
2005-06 Impreza
Offset: +55
Bolt pattern: 5x100
Wheel Weight: ?
Discussion Starter · #2 · (Edited)
BBS RK (Optional for Saab 9-2X, WRX)
Offset: +48
Bolt pattern: 5x100
Wheel Weight: 18.08 lbs (weighed by Amakirr)
JDM/EDM STi version 7
Offset: +53
Bolt pattern: 5x100
Wheel Weight: 17.5 lbs
2006-07 WRX
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 21.0 lbs (Mach V shipping scale)
2004 WRX STi BBS
Offset: +53
Bolt pattern: 5x100
Wheel Weight: 15.7 lbs (forged)
2005-07 WRX STI BBS
Offset: +53
Bolt pattern: 5x114.3
Wheel Weight: 19.55 lbs (forged)
2007 WRX STI Limited Enkei
Offset: +53
Wheel Weight: 21.2 lbs
OEM-equipped tire size: 235/45R17
2008 Outback Sport
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 22.6 lbs
OEM-equipped tire size: 205/50R17
2008 2.5i Impreza
Offset: +55
Bolt pattern: 5X100
Wheel Weight: 20.2 lbs
2008-2010 WRX
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 23.2 lbs
OEM-equipped tire size: 205/50R17 (2008), 225/45R17 (2009-10)
Notes: Clears four-pots
2008 STi five-spoke
Offset: +55
Wheel Weight: 27.5 lbs (thanks to NASIOC user Kostasdh for the weight)
OEM-equipped tire size: 245/40R18
2008-2014 STi BBS
Offset: +55
Wheel Weight: 20.5 lbs (forged)
2011-2014 WRX
Offset: +53
Bolt pattern: 5x100
Weight: 21 lbs (by shipping scale -- see post #206)
2011 STi Enkei
Offset: +55
Wheel Weight: 23.55 lbs (thanks to NASIOC member nashelton)
Notes: This wheel was also offered on the 2010 STI Special Edition, in a darker color.
2012 Impreza Sport
Offset: +48
Bolt pattern: 5x100
Weight: 24.x lbs (Postal scale - post #381)
2012 Impreza Premium
Offset: +48
Bolt pattern: 5x100
Weight: 16 lbs (postal scale - post #208)
2012 Impreza Limited
Offset: +48
Bolt pattern: 5x100
Weight: ?
2012-2014 STI, 2016-2017 Premium/Limited WRX, made by Enkei
Offset: +55
Bolt pattern: 5x114
Wheel Weight: 26.6 pounds
2018 STI (non-BBS)
Offset: +55
Bolt pattern: 5x114
Wheel Weight: 28.4 lbs (Myles at Racecomp Engineering, HERE)
OEM-equipped tire size: 245/35R19
Does NOT clear pre-2018 Brembos.
1998 22B BBS
Offset: +48
Bolt pattern: 5x100
Wheel Weight: ? (forged)
OEM-equipped tire size: 235/40R17
2018 STI Type RA BBS
Offset: +55
Bolt pattern: 5x114
Wheel Weight: 24.1 lbs (Mach V shipping scale) (forged)
There's also a bronze version from the 2020 Series.White STI.
The S209 gets a 9" wide version of this wheel, available in gold and gunmetal gray.
2019 STI S209 BBS
Offset: +48
Bolt pattern: 5x114
Wheel Weight: 25 lbs (bathroom scale estimate) (forged)
OEM-equipped tire size: 265/35R19
Discussion Starter · #4 · (Edited)
1997-2004 Legacy GT
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 20 pounds
2005-06 Legacy GT
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 20.5 pounds (need verification)
2006-07 Legacy Spec B
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 21 pounds (estimated)
OEM-equipped tire size: 215/45R18
2006-07 Outback
Offset: +48
Bolt pattern: 5x100
OEM-equipped tire size: 225/55R17
2007-09 Legacy GT
Offset: +55
Bolt Pattern: 5x100
Weight: 23.4 pounds (mrwillig)
OEM tire size: 215/45R17
2008 Outback XT/LL Bean
Offset: +48
Bolt pattern: 5x100
Wheel Weight: ?
2008-09 Legacy GT Spec B
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 25.5 pounds
JDM Legacy B4
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 18 pounds
OEM-equipped tire size: 215/45R17?
2010 Legacy GT
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 25.4 pounds
OEM-equipped tire size: 225/45R18
2016 Outback
Offset: +55
Bolt pattern: 5x114
Wheel Weight: 23.9 pounds (Mach V shipping scale)
OEM-equipped tire size: 225/60R18
Notes: Enkei MAT construction
Discussion Starter · #5 · (Edited)
2013 BRZ (and FR-S)
Offset: +48
Bolt pattern: 5x100
Wheel Weight: 20.1 pounds (need verification)
Notes: Does not clear FHI four-pot front brakes
Need photo.
2013 Legacy steelie
Offset: ?
Bolt pattern: 5x100
Wheel Weight: 22 pounds (estimated)
OEM-equipped tire size: 205/60R16
2013 Crosstrek XV alloy
Offset: +48
Bolt pattern: 5x100
Wheel Weight: Unknown, but looks heavy
JDM Legacy B4 Blitzen
17x7
5x100
55mm offset
21.5 lbs (bathroom scale)
2002-2004 Forester XT
Offset: +48
Bolt pattern: 5x100
Wheel Weight: 19 lb (bathroom scale)
OEM-equipped tire size: 215/60-16
2005-06 Forester XS
Size: 16 x 6.5"
Offset: +48
Bolt pattern: 5x100
Weight: 20 pounds
OEM-equipped tire size: 215/60 R16 94H all-season tires
2007 Forester XT
Offset: +48
Bolt pattern: 5x100
Wheel Weight: ?
OEM-equipped tire size: 215/55R17
2008 Forester Sports XT
Offset: +48
Bolt pattern: 5x100
Wheel Weight: 20.8 lbs
SG Forester STI
Offset: +48
Bolt pattern: 5x100
Wheel Weight: 26.2 lbs
Clears 4-pot Brembos
2009 Forester XT
17x7"
Offset: +48
Bolt Pattern: 5x100
weight: 22.9 lbs with TPMS sensor and some wheel weights.
2014 Forester XT
Size: 18 x 7"
Offset: +48
Bolt pattern: 5x100
OEM Tires: 225/55 R18 97H all-season tires
Weight: Unknown
OEM-equipped tire size: 225/55 R18 97H all-season
Discussion Starter · #6 · (Edited)
95 Impreza factory option
Offset: +55
Bolt pattern: 5x100
Weight: 14.5 - 15 lbs. each.
OEM-equipped tire size: 205/55R15
2006-07 Impreza 2.5i
Offset: +55
Bolt pattern: 5x100
Weight: 17.7 lbs. (estimated - see post #212)
1996-1998 JDM Legacy Twin Turbo GT-B Wagon (BG chassis) and TS-R Sedan (BD chassis)
Offset: +53
Bolt Pattern: 5x100
Wheel Weight: 17.8 lbs
2013 Legacy
Offset: +48
Bolt Pattern: 5x100
Wheel Weight: ?
OEM-equipped tire size: 215/50-17
2015-2021 WRX (base model only in later years)
Offset: +55
Bolt Pattern: 5x114
Wheel Weight: 23.2 lbs (Post 428)
OEM-equipped tire size: 235/45-17
2018-2021 WRX
Offset: +55
Bolt Pattern: 5x114
Wheel Weight: 24.46 lbs (Post 489)
OEM-equipped tire size: 245/40-18
Clears 6-pot Brembos. There are two versions of this wheel style. The 2018-2019 version does NOT clear 4-pot Brembos; the 2020+ version DOES. They are NOT identical, although the appearance is very similar between the two versions.
2015 STI BBS
Offset: +55
Bolt Pattern: 5x114
Wheel Weight: 22.1 lbs (forged)
Available in silver, gold, and gloss black.
2015 STI Non-BBS (Enkei)
Offset: +55
Bolt Pattern: 5x114
Wheel Weight: 23.72 lbs (post 628)
2016+ Factory-option Sport Package STI Wheel (Enkei)
Offset: +55
Bolt Pattern: 5x114
Wheel Weight: 22.2 lbs
The wheel above is also available in a 17" size for BRZ (7.5" width) and Forester (7" width)
Size: 17x7" (Forester fitment)
Offset: +48
Bolt Pattern: 5x100
Wheel Weight: 18.2 lbs (post 465)
Discussion Starter · #7 · (Edited)
2017 Impreza Sport
Offset: +55
Bolt pattern: 5x100
Weight: Heavy. (Need exact weight.)
2018 Crosstrek 2.0i and 2.0i Premium:
Offset: +55
Bolt pattern: 5x100
OEM-equipped tire size: 225/60R17
2018 Crosstrek Limited:
Offset: +55
Bolt pattern: 5x100
OEM-equipped tire size: 225/55R18
I kill threads!
There's the old Rays RE B20s which came in varying setups. 17 x 7 +48, 17 x 7 +53, 17 x 7 +55. The ones in the picture are 17 x 7.5 +53. They came in STI and non-STI flavor. I think just the decals and center caps were the only difference between the two. Believe they were optional wheels for the late 90s GC8, Legacy, and Forester. Not real sure though.
Wheel Automotive tire Hubcap Tread Rim
Can anyone explain why the Enkei's are heavier? They seem to be the same size and offset and bolt pattern. The enkei's also seem to be rarer and more sought after, but if they're heavier I'm trying to understand why? Is the weight difference because of the tires or are these specs only the weight of the rim?
2005-07 WRX STI BBS
Offset: +53
Offset: +53
I kill threads!
Size, offset, and bolt pattern don't matter for weight. Wheel design and how it's made is what matters. The STI BBS are forged, while the Enkeis are probably some kind of casting. Because of that, the BBS will be stronger. That'll allow them to have less metal on the barrels, spokes, center section, etc.
So in theory then, the 04 5x100 wheels are the best ones because they're forged and also the lightest? It's just odd to me that the 05 model would use heavier rims. Seems backwards which is surprising to me. I assumed that over the years they would optimize the rims to be lighter and stronger but it doesn't seem that way on paper at least.
It's even weirder that the jdm Enkei's are more sought after when on paper they seem worse for performance. I feel like I'm missing some info here, bc it just doesn't make sense to me.
1 - 12 of 12 Posts
