97 Subaru Impreza Wagon
So, I have been doing a lot of reading. I plan on turboing my 97 Impreza with a 2.2L. I have heard that my ecu is locked, and my car will need tuning but I won’t be able to? I have also heard, that the stock ecu will run it perfectly fine at around 6-8 psi? What is right and wrong? I have read a bunch of turboing NA Subaru’s and I just wanna do it right.
2002 WRX
Correct. If your ECU is locked, you will not be able to tune it unless you or your tuner have the code to unlock it.
I can't say if your locked ECU will run fine @ 6-8 psi but 6-8 psi is a standard base tune. Car will run fine at 6-8 psi but power will be very limited.
You will either have to find a good tuner who can unlock your ECU or buy an unlocked ECU off a WRX or STi.
If it turns out you need an unlocked WRX ECU, PM me because I have one.
I would love to just take yours off your hands then and skip all the trouble of dealing with limited power! If that’s alright
Yeah..Stale, old, forgotten post,......
If the OP is on a totally stock '97 USA model Impreza -the ECUs are not tunable - outside of a Subaru dealership. Neither are any from about '95-'00 for any USA Subaru. I've have multiple mid-90s Subarus, turbo'd a few of them.
There are no plug-n-play tuning options/ECUs. The few tuning options are either a full '02 USDM WRX harness swap, aftermarket EM 'piggy-back' or stand-alone systems such as Greddy Emanage or AEM , Mega/Microsquirt and I read about Speeduino - which might be the best lost cost option. There are other brands, but it's the same steps to make 'em work.
A JDM harness/ECU swap could work - lots of people have done the EJ20G swaps- but the overseas stuff was still OBD1 'til about '00, so their ECUs/Harness won't easily work w/the '95/'96+ OBD2 stuff, and the car won't pass emissions, if necessary.
The stock ECUs have not been 'hacked' to work with ROMRAIDER/ECUFLASH like the '02+ models, to easily modify the stock ECU's parameters to support a turbo install.
I've read of a few peeps purporting to tune these mid-90s ECUs, but they always disappear and don't 'prove' it works. Or may be they got hired by the CIA to perform secret hacker stuff? :)
