1 - 4 of 4 Posts
2001 A.W. L
1995, Impreza, 2.2L
Discussion Starter · #4 ·
4eats need ATF fluid. And its not as simple as draining and refilling.
http://www.rs25.com/forums/f105/t99571-diy-4eat-automatic-transmission-flush.html
as for your rear diff you just need a half inch ratched, remove the lower plug, drain. Install lower plug and remove top plug, refill until it starts to come out. Yes 75W-90 make sure its meant to work with LSD's
Thanks, 4 the reply josh
Can a high performance gear oil "royal purple work"? (75W-90)?
or wat do u recommend? My car has over 100K miles
1 - 4 of 4 Posts
