I've been on the lookout for some JDM V7 STI seats for a while now. I had wanted to stay similar era and V6 seats not often available. I also preferred the V7 blue as opposed to the V6 red. There is not much available in my local area but eventually found some on eBay. I set up alerts and would receive notifications each time a set came available, but many seemed to be in poor condition...finally was able to snag these:
The STI logo is a bit worn, so I may have that restiched at some point. After removing the original 2.5RS seats I took the opportunity to vacuum and shampoo the carpet and clean the seats. I have found the the "Green Machine" carpet cleaner works very well for a deep clean. For the seats I precleaned with "Sonex" alcantara cleaner then used the Green Machine and a dilute Woolite solution. I researched a bit before cleaning the Alcantara...and there seems to be no good consensus on how to clean. I erred on the side of safety with a process that would not damage the seats. They came out great.
Perhaps not immediately apparent is that the JDM V7 STI seats will have the drivers side height adjustment on the US passenger side...because the seats are RHD. This also means the JDM passenger seat is now the drivers seat and sits too high. So, the passenger seat will bolt right in albeit with some extra height adjustment - no modification necessary. For the drivers seat, the 2.5RS rails are lower and must be swapped to the JDM seat to allow it to sit properly. I should have taken more pictures of the rail swap...but once I started getting into it I had finished. Final product is awesome.
The rear seat back is a touch taller than the 2.5RS seats, and therefore does not fit perfectly. The backseat back has three rails that mount to the chassis. I was only able to get the middle rail mounted and the other are just too low...this outcome is endorsed upon my review of the forums. Cosmetically it looks great, and I don't believe there would be any safety implications.
Next post will be V6 STI front end conversion with V6 front lip and grill, OEM hardware, fog light covers with STI decals, and rear spats...all color matched with premium urethane paint. It's gonna be awesome! That will be my first painting project and I am trying to be meticulous in the prep. Stay tuned.
