My cam seal is leaking. I put in new cam seals before i put the heads back on the engine. Last weekend changing my oil i noticed oil leaking from behind the timing cover on the driver side. I took all the stuff off and replaced the cam seal. The cam seal looked alright to me, im not sure of the install depth but i though if anything if might not have been in deep enough. I made sure to push the new seal in farther than the last one. I used a socket to push the cam seal in. I was under the car again and noticed more oil on the timing cover.
What gives?
I wiped the oil off and will check again after i drive the car.
c/n: 2 new cam seals and 2 oil leaks.
What gives?
