1 - 6 of 6 Posts
Scoobymods Guy
2010 Legacy 3.6R Limited
http://www.scoobymods.com/forums/showthread.php?s=&postid=2489#post2489
There is my page on how to upgrade the rears to the larger legacy rotors on a GC8.
I did the write up pretty quickly and will have to go back and edit it probably. I worked 3rd shift and haven't gotten to sleep and I'ms starting to get punchy :p
I apologize in advance.
Night night
Peaty
Why the Legacy rear rotors? Don't the older GC8 body WRXs use ventilated rear brakes that are larger then the US models?
Scoobymods Guy
I think they do along with 2 pot calipers. The cost for the rotors and calipers is around 700 - 1000 though this cost me under 250
The 2000 and up Legacy Outback rear use a solid rotor 290mm x 10mm with a single pot caliper as opposed to the WRX Ver. 5 & 6 rear which is vented and measures 290mm x 18mm and thus requiring the 2 pot caliper and associated bracket hardware and pads. Also you could do the backing plates
I thought that I would elaborate but this is a good cost effective upgrade. hope this helps.
Troy
Actually I wasn't thinking of using a STI models rear brakes but a 1994 regular WRXs. Mostly cause it would cost me used about the same as what the Legacy setup in the US runs.
1 - 6 of 6 Posts
