41 - 54 of 54 Posts
Super Moderator
2000 RSTi
If you're talking front, the 02-07 WRX wagons had that from factory. Not sure what sedan had, but I run the wagon ones on my turbo cars (a GC and a BC)
2000 RS Coupe
Discussion Starter #42
Looking for a 20 mm rear bar. I know at least 1 production year WRX had a 20 mm rear bar, but I thought but they changed diameters through the 02-07 MY from 19-22 mm, depending on year.
Super Moderator
2000 RSTi
I heard the earliest of the 02 wrx sedans had bigger rear bars, and that Subaru changed it to smaller because people were wrapping them around trees ;)
I believe all 2004-2007 STI's came with a rear 20mm bar.
'95 JDM WRX wagon 2.5T
Can't remember if you've had this info?
Fit uprated mounting brackets for the larger rear bar:
20540FE200 reinforced mounting bracket from later model
20540FE210 reinforced mounting bracket from later model
2 x 20466FE000 clamps
6 x 901250075 bolt and washer
2 x 023808000 nut
You'll need the later version rear bar bushes as well.
2008 Impreza 2.5i
Does anyone have a 20 mm rear sway bar lying around that they wanna sell? I'm not sure what model vehicles this may encompass - maybe 02-07 WRX?
I have a used oem Subaru 20mm from a wrx. I can check on shipping if you message me an address. I will let it go cheap to a good home.
2000 RS Coupe
Discussion Starter #49
Can anyone confirm whether this front Whiteline passenger strut mount is alligned to allow for max camber / max caster orientation?
The bolt at the bottom of the picture would be closest to the passenger fender with the number "10" in the same orientation with the "14" facing the engine / front of the car. Thanks.
2000 RS Coupe
Discussion Starter #53
2000 RS Coupe
Discussion Starter #54
My outer tie rods bushings are essentially disintegrated so I'll have to order a set and install before I get an alignment. I figure I'll replace front swat bar mounts and endlinks as well. Ideally I'd like to replace stuff with Whiteline products but goddamn their stuff is expensive! I also purchased a used 02 WRX 20 mm rear sway bar from a fellow RS member. I'll be replacing endlinks and mounts in the rear as well. After alignment I can put these on:
https://flic.kr/p/2j75z4b
41 - 54 of 54 Posts
