1 - 9 of 9 Posts
Zenki 1995 Impreza WRX in glacier white
hay guys. I need to do a clutch on my jdm wrx, I'm wondering if a usdm 2002 wrx clutch will fit my car. it's a five-speed.
2000 RS Coupe
Should be the same if memory serves. I have a V6 JDM STi Type RA 5 speed transmission and I believe the clutch kit I have is from an 02-03 USDM WRX.
2000 RS Coupe
This is a thread I started a while back asking about driveline swaps. Towards the end, FryphaX states that a clutch kit for an 02-05 WRX will fit the bill, so yes, an 02-03 WRX clutch kit should work.
my trans starts with ty752 and it says in the thread I should use the 2.5rs clutch kit
2000 RS Coupe
Trans starting with 752 is what the USDM 02-03 WRX came equipped with. USDM 04-05 WRX transmission codes, as well as JDM cars began with 754. Ultimately it doesn't matter - all years use the same clutch kit. They're all for 2.0 L turbo engines. Again, 02-03 WRX clutch kit should be fine for your vehicle.
2000 RS Coupe
If you check PNs on Rockauto and choose Exedy, for example, 2000 RS calls for KSB04, wheras 02-05 WRX calls for KSB03, so go with the WRX not the RS
Discussion Starter · #8 ·
on the other thread this guy said
you all have missed the barn as OP has Suretrac R160.
If the transmission ## starts with 752, you can use all of the 2.5RS clutch set. While you're at it, you can swap out the shift fork and Throw-Out bearing with a 06-07 WRX which is stronger
I just found a resource saying that the usdm wrx(02-03) comes with a ty754 trans as well.
would you happen to know if a 2.5 rs flywheel would fit an ej 20 g?
Administrator
2000 RSTi
A 2.5 RS flywheel will fit an ej20g. But the 2.5 RS flywheel is NOT compatible with a WRX clutch kit.
All flywheels made for any EJ engine Subaru will bolt to any other EJ engine. But... You have to match the flywheel to the clutch kit.
1 - 9 of 9 Posts
