1 - 7 of 7 Posts
because i just bought a 99 rs and was just wondering. Is it bad to leave them open because of water/dirt to hitting the engine?
the engine is sealed. no worries.
as for opening them up, go ahead if you like. the vents do aide in cooling the engine bay when its hot, but without an intercooler to feed, the scoop doesn't do a whole lot, except if you modify a MY00-01 to have a ram air intake. you can't on your MY99 because of the MAF sensor. basically, i leave mine open during the spring, summer, and fall and then close them during the winter when i'm actually trying to keep the heat in the engine bay.
they're just an accessory unless you have a turbo...
they aren't really going to aid you in anything by removing the backing plates...
the 2.5 RS we have is based off of the JPN/UK spec turbo cars... they just left the design as is and installed the scoops as we dont have turbos....
so unless you enjoy cleaning your engine often...
leave the backing plates where they are... ;)
that's my take on it anyway...
cheers
Jamie
www.subiegalracing.com
Scoobymods Guy
2010 Legacy 3.6R Limited
http://www.scoobymods.com/forums/showthread.php?s=&threadid=58&highlight=Hood+vent+spacers
http://www.scoobymods.com/forums/showthread.php?s=&threadid=60&highlight=Hood+scoop
If you look at the above links those mods will allow air in but keep out rain and dirt for the most part. I took real time temps under the hood and removing the plates keeps the motor cooler by washing air over it. As stated air comes in the scoop, and out the front vents. The second air box (aka torque box) will get heat soak after a while and raise the intake air temp. Opening the scoop keeps it cool.
Peaty
Silver 2K RS Coupe
I have had my plates off for a long time and underhood temps do indeed stay lower.
Only problem I have had is clutch creak, which MAY be due to water washing away grease on the clutch slave or fork. A little lube and it's fixed, so I keep them off! :)
1 - 7 of 7 Posts
