1 - 1 of 1 Posts
some may have read this on prior temp site but here goes again,Have had problems with boost only going 5 pounds Hence"fail safe mode" have repalced knock sencor,tried another computer,reverted back to standard chip as was getting no error codes on diagnostic , since trying all this it has being very much to no avail other than going back to standard chip im getting an error code going on about "ICS or ISC valve" which has also being replaced,also the only way the computer can be cleared is via daignostic tool,battery disconnected over nite doest work , recently i got some info about two grren and two white plugs under the dash which appear to be of no use as the ends with plugs are not connected,apparently by plugging in one white and one green and (there are only one set that will interface) driving till engine check light flashes,this was also of no avail,on the conclusion of some where in the wiring isn't earthed or a short some where,When computer is cleared it can go well for anything inbetween 5 and 50 km before reverting,,if anyone can shed any lite on this would be appreciated
1 - 1 of 1 Posts
