1 - 20 of 21 Posts
Hi Everyone , just started this a few weeks ago and thaugh I should share it, wrx engine swap planned and complete body job, i bought the car cause it only have 127 000kms so not bad for a 1997 car
84591
Discussion Starter · #2 ·
so l am stripping the whole car right now , I already bought the wrx engine/trans/wiring harness, 4pot / 2pot brakes , aluminium V6 hood and a few other things , cant Wait to work on the car again when I have more time
84628
84629
84630
84631
Super Moderator
2000 RSTi
A coupe and you didnt get the nasty tan interior! Awesome! Sounds like it's gonna be a fun build.
  • Like
Reactions: SoCoNoHa
Discussion Starter · #4 ·
Yes , I was pretty happy with the black interior , hope I will be able to run this dash with the new harness , id rather keep this one than put a gd one in
Made some work on the car , engine and trans are out
84643
also got this authentic zero sports hood splitter
84644
Super Moderator
2000 RSTi
What tmic do you plan to use?
Discussion Starter · #9 ·
Still working on getting the chassis 100% rust free , then I will be painting all the underneat with antirust paint before starting to put it back together, car is then gonna be painted in bright red color
85403
85404
85405
Discussion Starter · #10 ·
Finally found a donnor 02 wrx and got to work on the car again after a few months , i'll keep the thread updated in the next few weeks as im going to work more on the car
86697
86698
Discussion Starter · #11 ·
Got a few more parts for the car
jdm wrx 17" wheels in almost intact condition
86760
86761
Wangan wrx axelback made by Apexi
86762
86763
Super Moderator
2000 RSTi
Nice man! Love a good "built in a shed" project
2002 Black Impreza 2.5 TS
Really hope no one got hurt when you turned that car on the side that way, wow thats creative.
Discussion Starter · #14 ·
It went pretty well ,we were only 2 to put it like that , I welded some attach point on both bumper beams at balance point . I am able to turn it by hand . Im glad I was able to put it on the side like that , 1000x easier to work on the undercar
Discussion Starter · #17 ·
So today i put the car back on jackstand and Ive fitted the gd dash + dash beam in the car , few extra holes cuts had to be done but not bad at all . Im pretty happy with the dash gaps
86776
86775
86777
both dash
86778
marked where the new holes had to be done with the template
86779
what needed to be cut on the middle part , if you dont cut its rubbing against tranny tunnel pretty bad
86780
this is what i removed from the dash so it fits perfectly against the firewall
86781
86782
86783
now I need to fit the heater box an then I'll be able to start putting the harness back
Nice work. Love the details in your build thread. I’ll be doing a dash swap and full harness at some point.
Also what’s the rotisserie thingy to turn the chassis over on its side like that. I don’t know the terminology so I can’t search for it. Haha
Discussion Starter · #19 ·
Thx, I actually just modified an engine stand so it can rotate and it was attached to some mount I welded to both bumper beam , it did the job .The real thing is over 1000$+ and for a one time use Id rather spend the money on parts . Here is a link to one Auto Lift CR-3000 Car Rotisserie
Discussion Starter · #20 ·
So I almost finished the dash install and started the wiring job
86799
86800
I installed the gd steering column and the pedal set too. Steering column fit good u just have to change the gromet that passes through the firewall and I think I ll maybe have to modify something when I put the steering rack back on . The pedal set fit pretty good too just had to cut the upper right tab on it
86801
the brake booster and clutch master cylinder are installed too just had to enlarge holes a bit
86802
some parts that I prep and painted going back on the car
86803
still waiting on a few parts in the mail to continue the interior including new carpet 😁
1 - 20 of 21 Posts
