1 - 4 of 4 Posts
1993 Impreza wagon AWD
I finally got my car back and it is running now. Unfortunately, I have no lights to my dashboard, parking lights/corners, and normal tail lights. My headlights, blinkers, and turn signals all work fine. There are no burned out fuses to my knowledge and I was told that I'm probably going to have to tear out the wires in the dashboard. What should I be looking for?
The car just got a new engine, just for reference, and this has never happened before.
Moderator
06 Wrangler Unlimited
Double check all the fuses before you go tearing apart the dash. I think the fuse for that is usually labeled "Tail Clearance."
But if you are sure it's not a fuse, then just start taking the dash apart and looking for places where the insulation on the wire has been taken off somehow (usually from some shatp piece of metal)
Discussion Starter #4
For some odd reason, my tail lights are wired to my parking lights now. I have lights now, but my dash lights still don't work. I don't understand why or how my headlights were wired to a separate circuit than my tails, but they are. Now, it's on to investigating the dash lights and my front passenger side power window.
1 - 4 of 4 Posts
