i want to add cruise control to my 98 rs. what components will i need? can take them off a legacy? i searched and couldnt find any good info. write ups available?
thanks.
thanks.
the the butterfly actuator at the throttle body (the thing that the accelerator wire connects to and opens the butterfly valve) has a second acturaor ready for the cruise control wire. is that normal? but otherwise there are no signs that it ever had CC.did your 98rs come without cruise too or was that not an option?
james
what clock spring, and where are thes wires you speak of? how much for he parts you have?I'll sell you the actuator and the cable if you want it. I just took it off when I did my swap. I also have the control unit. If you have the wiring diagram for the 99-00 you can see how the wiring should be run.
You will also need a clutch switch, and different brake switch. You will need the buttons and lever from the steering wheel, and probably the clock spring too, unless yours is the same. (If it has 5 wires it is the same.)
i saw that i thought it came with it and the owner before me took it off. but that good to know i am not the only one with out it.the the butterfly actuator at the throttle body (the thing that the accelerator wire connects to and opens the butterfly valve) has a second acturaor ready for the cruise control wire. is that normal? but otherwise there are no signs that it ever had CC.
