1 - 7 of 7 Posts
How do I get this coolant tank to fit this manifold or is there another one I should use. It's a JDM ej20g motor.
11 wrx & 15 fozzy 2.5i
that engine uses a different one, but i would mount that tank on the only mounting pint in that picture, once it has all the hoses attached it would now fall.
RS, GF, SSx2, STI GDB
You can use spacers or brackets to make it work though.
Agreed- you can still use it. You will just have to drill one or two holes on the right side to correspond to the mounting holes in the manifold. You can take the coolant tank apart so you just have the mounting bracket part and use it to determine where to drill.
1 - 7 of 7 Posts
