1 - 3 of 3 Posts
1998 Impreza 2.5rs
I just bought a 98 rs with a jdm 5speed swap from auto and I'm trying to hook the reverse lights up because the previous owner was too lazy to do so, when I hooked them up they just stayed on so I undid them and now my gauge cluster doesn't show my mileage or the parking brake light. I don't know what could've happened when they were working fine before I tried hooking up the reverse lights.
1998 Impreza 2.5rs
Discussion Starter #2
I tried hooking up my obd scanner to see if the sensor code pops up and I'm not getting anything to the plug to turn the scanner on
1998 Impreza 2.5rs
So after digging around and looking through the wire harness, I seen he cut and spliced a bunch of wires (very poorly) to get the manual trans to work. So I'm just going to pick up another ecu and harnes out of a 98 manual forester that way everything should hook up with no issues. The sad part is the guy I bought the car from works at Cosworth in Indianapolis and he does the wiring, I know he works there because that's where I got the car from and he took me and my friend around the shop.
1 - 3 of 3 Posts
