1 - 2 of 2 Posts
I'm putting a 99 rs bumper cover on my 98 OBS Wagon. Naturally I'd like to replace the fog lights. The car has a switch, not being used at the moment, as I removed the original fogs when I put a ram air system behind the right front unit. This way I'm getting uninterrupted air flow to the new intake.
Question is: Once I get the bumper cover on, can I hook up either a set of Hella's or PIAA's by just using the existing harness, which is original to the car?
Thanks for any help, Ron
Scoobymods Guy
2010 Legacy 3.6R Limited
I swapped out the OEM lamps on our 97 OB and just used the existing wiring. Just cut off the plug and put the new one on there. But the lamps were the same wattage (55W) as the OEM ones so there was no problem. If you go higher in Watts I think you should use the harness that comes w/ the lamps. You could probably rig the relay to work off the OEM switch though.
1 - 2 of 2 Posts
