Which High Performance Brake Fluid Should I Use?
  • Motul
    Votes: 13 31.7%
  • ATE Super Blue
    Votes: 22 53.7%
  • Other
    Votes: 6 14.6%
  • Total voters
    41
1 - 20 of 46 Posts
The Silverback Mod
05 Black OBS
I am getting ready to swap my pads (EBC Green) and install SS brake lines (Goodridge), it's also time to flush the brake fluid out and say goodbye to the OEM fluid.
Which brake fluid are you running and why?
Part Deux
2001 WRXed Caged L
Motul.
Last summer, I ran my SRT-4 in three different open track sessions at Heartland Park in Kansas in one day with no brake issues at all. Then the next day we ran on the autocross track and still had awesome working brakes. I highly recommend Motul.
turbocharged mayhem
MBP 03 wrx wagon
I use valvoline synpower brake fluid. Its not as good as some of the other stuff, but its cheaper and can be found just about anywhere
503f dry
343f wet
I run the Valvoline stuff in my street car as well. I like to bleed the brakes along with my oil changes and it is a lot cheaper so I don’t mind wasting a bit to keep my brake system at 100% all the time. "Brake fluid unfortunately in not like fine wine"
2000 Imp 5 door Sport
what happens if you don't change the fluid for a while will it just lose its edge? or will it become unsafe i don't know much about brake fluid
turbocharged mayhem
MBP 03 wrx wagon
Brake fluid attracts moisture over time lowering your boiling point. I dont believe dot 5 attracts moisture though.
HERO DEEP!!!
Lt. Dan the 2000 OBS
you car comes stock with DOT3, which you SHOULD replace every year, you replace it due to contaminants and moisture absorbtion.
1 - 20 of 46 Posts
