So, I was driving home from work, and my high beam light in the car (the blue one) was kinda faded, I couldn't tell if my high beams were on, and it was slowly getting brighter the more I drove. Once there was nobody in front of me I flipped on my high beams and they shone bright and the blue light inside the car got bright telling me that they were on. I turned them off, and the blue light didn't go off, and neither did the high beams. If I turn my lights off, they go off, but when I turn my headlights on, with or without the high beams activated, the high beams turn on. I can not revert to normal headlights without high beams.
My conclusion is that I need to replace the headlight stalk attached to the steering wheel, probably the switch went bad. Sound about right? If anything else went bad, I would imagine they just wouldn't turn on, but not turning off seems like a bad switch. Anyone agree, or is there something else I should check? Maybe now is the right time to replace the other one with the ol' intermittent wiper switch as well. Any fancy options for the headlight one, or are they all the same? No crazy cool must-have jdmYO headlight stalk conversion?
