1 - 3 of 3 Posts
2002 Impreza WRX Wagon
Please help, during a recent snow storm my son slid into a curb and caused some damage to his 02 impreza wagon. I have replaced a damaged strut, it was bent just above the bracket the rear knuckle bolts onto. The top of the tire is still sticking out past the bottom of the tire (way too much positive camber). I tried installing a camber adjusting bolt from ingalls engineering, but it didn't seem to help. I have inspected the parts under the car and cannot see what else might be causing the issue. Any tips would be appreciated.
needs more cowbell
95L, 07 2.5i, R6
the two parallel lateral links connecting the subframe to the bottom of the spindle may be bent
"the two parallel lateral links connecting the subframe to the bottom of the spindle may be bent"
Thanks I will look at them closer...
1 - 3 of 3 Posts
