1 - 10 of 10 Posts
98 2.5rs
The backlight on my AT shifter no longer lights up. As you can imagine this is pretty awkward at night where i have to put my map lights on to see what gear i'm in.
I've taken apart the centersole to look for loose wiring and didn't find any, also checked out all the lighting related fuses and they are ok.
Do you guys have any other ideas?
98 Impreza RS
98 2.5rs
Discussion Starter #4
Initialdaddict said:
Um... you haven't memorized the shifter positions yet?
Nope and after a near miss i don't think i'm gonna try :wtf:
As far as getting at the bulb, any little tips or warnings i should know about or is it just a matter of unscrewing what ever screws i see till i find it?
Moderator
06 Wrangler Unlimited
Yeah, just basically start unscrewing stuff. Doesn't hurt to pull the e-brake before you begin though, just in case. :)
On my '93 its was bulb #194. Probably the same on your '98 but who knows.
98 2.5rs
Discussion Starter #6
Thanks gotta a little time before it gets too dark outside gonna see if i get at it now.
98 2.5rs
Discussion Starter #7 (Edited)
err..... how do i remove the shift knob so i can lift the housing up to look at the underside where the light bulb is?
98 2.5rs
Discussion Starter #9
Grrr took of the two screws on the shifter but still no luck, guess i should find a service manual before i break something.
1 - 10 of 10 Posts
