2000 BRP RS
Can anyone tell me how to do this and what type of bulbs I may need? Thanks-
Robmat
You need to remove the radio and climate control. The tricky part is delving the wires that control the fan and temperature. You disconnect. All sites and rake off all knobs .. you will see the switch there you disconnect it and tap it out from the front side to slide to the back. The bulb has to be bought at a dealership is very small and had a connector. This is from a 99 2.5rs
