1 - 6 of 6 Posts
Hi Guys, I've had trouble identifying this issue and it's been dragging out (registration renewal way over due).
Background:
I got 'randomly' tagged for STAR Smog inspection which is more extensive than just the normal 2 yr smog. Took my 2001 2.5 RS in for smog and failed for what the mechanic thought was Drive Cycle.
Hooked up my OBDII reader and it showed "Mode $06, bank 3 - sensor 1 fail" - see images below.
No Diagnostic Trouble Codes have been thrown but from my research Mode $06 is related to emission faults, sensor on verge of failure, or possible engine misfire. The car is running great so don't think it's a misfire issue.
I've replaced the rear 02 exhaust sensor, ran drive cycle ~100 miles and still throwing the same fail for bank 3 - sensor 1.
Can someone help verify if I've replaced the correct exhaust sensor. There is the front one which i haven't replaced just yet assuming the rear was the culprit.
Thanks in advance.
Font Screenshot Technology Multimedia Software
Font Slope Screenshot Terrestrial plant Technology
Administrator
2000 RSTi
It most likely means you have a pre o2 sensor exhaust leak due to the gaskets being toast or cracked exhaust. Or your catalytic converter(s) are toast.
Thanks for the feedback Mike! Should I just get new exhaust or try to replace all exhaist gaskets and maybe front 02 sensor? Right now setup is a stock exhaust with an axle back mod
Administrator
2000 RSTi
I would start with the gaskets.
1 - 6 of 6 Posts
