You have to put in lower compresion pistons if you are going to go over 5-6 psi of boost. Lots of guys have stock RS motors with 5 psi turbo and some fuel & ignition control with no problems.Fitz said:I dunno. I heard they blow up if you turbo them. Wouldn't it just be easier to buy a WRX?
Fitz
www.Flat4Racing.com
*nods head*... while the 0.3 liters of displacement may not be noticeable, the 10.5 compresion motor to the 7.8:1 compression motor is very noticeable. Doesn't help that I have a turbo the size of my head either. Looking to fix the lag problem sometime in the near future.Fitz- Was there a big difference in lag going from the high compression 2.5 to low comp. 2.2 hybrid? Or is it due to the T3/T4? Your running a Minnam kit, right?
*shrug*..... bought almost all of it used. Ebay... NESIC... Between Charlie North, Wayne Chin, Ryan Catucci and plenty others, the labor hours are endless.wish i had some of that stuff to work with.
Hooked on phonics is your friend.geoff999 said:damn where the hell is every one i got a 99 2.5rs wiath a forced tech stage 3 turbo in the mail a light weight flywheel and an act clutch what the hell does every one else run
Just pointing out that your grammar and sentence structuring sucks. I'm all for getting your point across with as few words as possible, but that was anything but coherent.geoff999 said:whats that aboot man ????
