Hi guys! I am Akos from hungary.
Please help me! I wanna read ecu from my car 2005 impreza GX 2.0 .
the freessm is good working, but ecuflash or romrider or ecuexplorer is not. I plug the green test connector under the steering wheel ,is working(the fan on-off etc), but i see the one white connector, this is unknown to me(in white connector only 2 wire), anybody know help me? Thx
I want modified burble sound only, no tuning or optimalization...
82194
Discussion Starter #4
[QUOTE = "02OBS25L, hozzászólás: 3627811, tag: 18876"]
"Csak módosított burble hangot akarok" egy egyenlőtlen hosszúságú fejlécet (Headpipe) szeretne.
[/IDÉZET]
No! I spoke bad: i have an UEL header and coming good sound, i want pop(burble) when i shift or push off the gaspedal :) (want modified the ignition time B in ecu)
07OBS
I'm not sure if 2005 ecu is 16 bit or 32. if it's the older type they are tough to modify.
Subarus run rich so if you floor it quick and let off right before you shift you should get your desired snap crackle pop especially with a straight pipe. I have a full 2 1/4" exhaust on my 2007 with no resonator and it backfires a few pops between shifts when I'm on it hard.
