So I'm looking for help on diagnosing a problem I discovered just as I came home from a track day.
Coming from the front right, I started getting a knocking sound. It would start doing it at certain speeds, stop sometimes, then continue randomly. I pulled over and nothing was hitting, everything looked normal. I was almost home so I parked it and decided to check it out this morning.
So I inspected both CV joints, the brakes, and anything that would be making contact. Nothing, so I disassembled the brakes and got it just down to the hub (with axle attached).
When turning the hub by hand, it would reach a certain point then "click" a few milimeters over. It would just sort of give out at a point then stop again normally. When rotating the wheel in the air, it would make a noise that sounded like what I was hearing last night.
So I decided maybe the axle wasn't seated well in the hub and put my impact on the axle nut and got a quarter turn out of it, knocking some debris and rust free at the same time.
Turned the hub again and the noise was gone..seemed to be moving smoothly. Put everything back together and put 10 miles on it, and it seems to be back to normal. However I'm concerned its going to come back. Anyone have any idea what it could be?
Wheel bearing tests fine, there's no play in it.
