1st post,
I have already posted this on the i-club, but I cannot get much help, I have already checked all of the normal things and I have everything setup how it should be. These are all of the posts that I had from the i-club thread:
2nd time around, I have all of the right stuff, but I am stumped.
I will start by giving the list of what I have:
Legacy turbo setup with only around 3-4 psi (lower than before)
SVX fpr(34 psi at idle) and vortech 6:1 FMU(around 60 psi at boost)
Walbro pump
Magnecor wires with NGK step 7s
J&S safeguard (kinda helps but does not fix anything
EGT on #3 around 1250-1275 at cruising, around 1500-1550 while WOT (This does not really help because it is pinging on the driver's side)
----->Should'nt this be enough to keep me from running lean???
mcgyver and I spent some time on trying to figure it out and it is probably either the #4 running lean due to an injector or maybe a problem with spark like Larry Ganz had. The only weird thing is that when I bought this car with 17000 miles, it had a burned electrode on one of the Denso plugs (and I cannot remember if it came from the driver's side where I hear the pinging) Reguardless there must have been something wrong for it to have burned up a plug. This is why I am thinking it might be a problem like Larry Ganz, even though it is not really a misfire. It just rattles while WOT. The J&S picks up something, but I do not want to avoid the problem. I can have the J&S help but it would retard too much to get it to stop. I am going to try to put some race gas in tommorrow (mix 50/50 100+91) but even that will not be a true fix, and I cant afford that for too long. SOMETHING has to be haywire. (ALREADY TRIED DID NOT FIX IT)
So, now I am entirely frustrated with this thing. The car stopped pinging only for a while after doing the ECU reset and messing with the plug wires. Now it pings, but the J&S does pick it up. But I have to have it so sensitive to where it hurts the performance. I really need some serious help. If somebody could please help me try to figure this one out I woulld really appreciate it. Like I said before I have about 64 psi of fuel at boost and I think that would be enough to stop it from pinging. The EGT probe is on the #3 cyl, but I hear the pinging from the driver's side. #3 is about 1250-1275 at 65 cruising and the times I have gone faster it would stay around 1500, which is good as far as I know. I have done a compression test and all cyl are at 185. Plugs all look good with tan residue. The only thing I can think of is that maybe the SAAB intercooler is not efficient enough, even though I never had a problem on the other car. And it is low boost. I had a guy scan the data and everything looked good except he thought the timing was too advanced (even though he is not a subaru guy). It said the timing was at 40 degrees or something. Please help, my turbo is useless at full throttle.........................
I have a Vortech 6:1 and am only running around 3-4 psi. I cant see why I am running into problems. The AFR guage is after the two cats and reads green(rich) during boost. So you think I need more fuel pressure? That means I would have to have a 8:1 or an adjustable one. A lot of people run 4:1 with no problems. I even swapped the SVX fpr for the stock one and it gave me around 70 psi at boost. I think I am going to buy another probe and have a switch for both #3 and #4 to use the same guage.
This is pretty much my whole problem, maybe you guys here can elaborate.
Thanks,
scootr
Walbro pump
Thanks,
scootr
