the cometic is a bit thicker....so it will lower your compression slightly....round 2 of comparison - what are the pros and cons of each head gasket, what one do you feel is better, and what would you recommend for an ej251/ej257 build
i beg to differnothin beats OEM parts![]()
reeeeally, i WAS gonna get cosworth's but i figure my build wasn't as extensive so i went for the cometic's. thanks for making that clear.The Cosworth gasket is virtually identical to the Cometic, so take that into consideration when choosing.
For those engines, the STi HG works well no doubt. When you start pushing 500whp++ you begin to worry about the heads lifting. The STOCK HG seems to work very well. For my EJ22T build I use the '97-'98 EJ22E, which is a 3layer HG just like the STi HG. I have no problems with it, but I am only pushing about 300whp.round 2 of comparison - what are the pros and cons of each head gasket, what one do you feel is better, and what would you recommend for an ej251/ej257 build
