1 - 6 of 6 Posts
2001, Outback Sport
any reccomendations for a shop to do head gaskets on a forester 2.5 01? leaking oil from headgasket junction on passenger side...car still runs great, just hoping to hedge any further possible damage, avoid stranding.
thank you.
Miatamiatamiata
Do more searching about your year, I do believe the oil leak is external only, meaning it won't get worse, and it just means check the oil level each time you fill the gas tank, and top up when necessary.
If you decide the engine needs a HG for some reason, then MLS is the way to go, the Factory subie ones are pretty cheap.
Why are we responding to posts that are over a year old?
Banned
The external leaks get bad to worse, I've seen a few where the car needed to be thrown away! If you want to keep the oil inside your engine, replace the head gaskets.
1 - 6 of 6 Posts
