Alright guys, this is not about how to install it or a comparison.
Let me tell you guys what I think about it.
It does absolutely great and does what it is advertised to do on a street car.
It does an amazing job at seperating the air from the oil for street car use.
Street car use includes; you street racers, dyno users, and touge runners.
But if you plan to track the car, I have only one suggestion don't use it.
WHY???? you may ask, if it works so well on street cars.
Well first of all after each session at the track, I get HUGE amounts of blowby. By a lot, I mean if I shut off the car after a session to cool down then proceed start it back up right before next session starts, bellows of smoke with a blue tint (which mean burning oil) comes out for a while until it clears.
Before you say anything about a turbo car having blowby etc, I understand it will have blowby even stock on a turbo'd car on the track.
(keep in mind with the stock setup I did not get this much at all!)
Second of all the car's oil started to have lots of fuel mixing with the oil, it smelt straight like fuel.
The problem I believe is that the aos does not have enough capacity to separate all the vapors or the oil quick enough during constant high rpm and aggressive driving during track days with high cornering G's.
My car has nothing crazy done to the motor if anyone is wondering.
06 wrx ej255
Stock long block
Stock intake
sti tmic
vf39
aps hard inlet
pnp throttle body
pnp intake manifold
pnp tgv delete
3mm phenolic spacers
full tbe
I am running 18.5 psi for boost if anyone is wondering.
Let me know what you think, or if you have had similar events.
I am currently looking for more alternatives!
06 wrx ej255
Stock long block
Stock intake
sti tmic
vf39
aps hard inlet
pnp throttle body
pnp intake manifold
pnp tgv delete
full tbe
