WHAT IS IT?
An external wastegate allows the exhaust gases to be diverted prior to entering the turbo. Dumping the exhaust gas prior to the turbo helps with boost control, maintains boost longer in the rpm range, and extends the life of your turbo. Our pipe is fully built stainless steel EWG Up pipe and stainless steel dump tube for turbo Subarus. Monster thick SS flanges that will not warp. We have added a flex section which extends the life of the product and will lead to less exhaust leaks
because the pipe can flex vs. warping the flanges in a non-flex setup(inturn creating leaks).
WHY DO YOU NEED IT?
Reason for switching to an EWG setup includes:
GAINS?
Users should expect gains in the 15-40hp range when tuned for the EWG setup.
Another unique aspect of our package is that we include a bracket that holds your stock internal wastegate shut. This is great because you will no longer have to weld your turbo door shut which means you have no chance for leaks and you can revert back to stock anytime you want with no hassle.
Want to learn about external wastegates? Informative video:
http://www.youtube.com/watch?v=PA5T5PnWE-k
FITMENT
02-08 WRX
04-08 STi
05-08 LGT
05-08 FXT
93-01 Turbo Subarus
PACKAGE CONTENTS
EWG Up Pipe
Dump Tube
Area1320 Bracket to hold stock wastegate closed(no more welding!)
5 Studs for Up Pipe
2 Allen head bolts for dump tube>wastegate
Bracket Options:
TD04
VF Series Turbos
FP Green/Red (3" inlet only)
Deadbolt 20g/18g
LINK TO PRODUCT
http://www.grimmspeed.com/catalog/index.php?cPath=22
PRICE
319.99
We offer ceramic thermal coating for both pipes(up pipe and dump tube) for 29.99.
Justin
www.grimmspeed.com
AIM: GrimmSpd
612.481.5731
