1 - 8 of 8 Posts
2002 WRB WRX
I know that there are a couple threads out there on this subject and I have read through some of them quite a bit but I just want to get a better grasp on the subject. I need to do a gas tank in my girlfriends 2000 2.5rs coupe. I know it's an extensive project and I know how to go about doing it. But I just want to get a positive answer. From what I've read a 2002 WRX sedan gas tank is a direct swap into the 2.5 RS. Can anybody make a positive confirmation? All input and ideas are welcome thank you for any advise. :)
2002 WRB WRX
Awesome. Thank for the quick response! Looks like I'm going to be having fun this weekend ha.
01 Impreza 2.5RS, 95 Civic VX
Don't count on it. Impreza from 93~07 are practically interchangeable from drivetrain to suspension.
99 Impreza RSTI
up to 07 will be a direct swap. One thing to note, if you are going to replace the fuel pump assembly, 02+ has a slightly different pinout on the connector coming from it.
The easiest thing would be to reuse your old one, or you can rewire it.
Alex
Not worth it to me to go through all the hassle with fuel pump assembly and rewire harness. There's no performance gain for N/A with more trouble, I'd swap only if swap WRX engine to my RS.
bumping this thread for input. will a gen 3 legacy tank fit my GD? the B4 tanks are 64L :D
(the gen 5 legacy tanks are 70L so i'd swap one of those instead if it'd fit...)
1 - 8 of 8 Posts
