1 - 7 of 7 Posts
Strange thing happen this morning. I got in my car, started it, and started backing out of the garage when the low fuel light came on and the guage slowly fell to empty? I quickly checked to make sure I wasn't gushing fuel, which I knew was not likely, then shut off the engine.
I cycled the ignition and started the car again, fuel still showed empty and now the CE light came on!
I shut it off, grabbed the laptop and hooked it up and checked the codes. It indicated "Fuel Level Sensor Input HIGH". I then backed it out into the street and PRESTO! the fuel light goes out and the guage goes back to 3/4 tank.
I cleared the code, and all seems normal now.
Has anybody else had anything like this happen?
:confused:
Car goes in wed for the recal reprogram.
Lygriek
Happened Again Today
This time while driving, I made a very hard laft at about 40mph and the low fuel light came on and the gauge dropped to about 1/4 then wnet up to 3/4 and stayed there, but I have a full tank?
I am going to check the seal around the float and see if it might be leaking or something. Both times this happened I had a full tank of gas?
Lygriek
MY00 Impreza 2.5RS, Aspen Whit
I have been having the same problem too. Now its saying like when I leave work its at 1/2 tank and by the time I get home it falls to 1/8 full. I don't work that far away.
Someone told me I probably had a bad Sender on my Fuel Pump. I never checked it out though. Just get gas more often
Wow!
Wow!
Its been almost two years since I posted that, don't even have the Impreza anymore, which makes me sad :( But, I do remember that it turned out to be a bed sending unit in the gas tank. I traded it in at the Mitsubishi Dealer where I worked and they wound up having to fix it, lol.
Man I wish I had my Impreza back, this Montero is KILLING me in gas.
:bonk:
Discussion Starter · #7 ·
Yeah, maybe if I wasn't sooooooooooooo buried. lol.
Besides, you ever seen one of these things airborn?
Plus, I engage the AWD and drive Bouquet Canyon like it was my Impreza.
1 - 7 of 7 Posts
