FS: Pioneer system
I traded in my car and I no longer need this item. I could not remove all the wiring from the vehicle so, some of the cables will need to be replaced. If you have it professionally (recommended)installed they will have the wires instock.
Link below. I purchased it in December it's still new.
I have added a 12 disc changer to the mix.
retail value for the changer is 250 give or take.
The deck alone brand new is $2300
I am selling the deck,remote, 12 disc changer for $1700.
All I can say is that this deck is awesome.
Need to sell asap.
http://www.pioneerelectronics.com/P...9,32435,00.html
Ultra-Slim Built-in DVD, Video CD/CDPlayer
DVD-R/RW & CD-R/RW Compatible
96kHz/24-bit D/A Converter
DVD Video Output for Rear Display
Optical Digital Output (Dolby®Digital/DTS™/ Dolby Pro Logic/Linear PCM)
7" Widescreen TFT Active Matrix LCD Color Screen
5 Selectable Viewing Modes
Fully Motorized Unit with Display Angle Adjustment
RGB Input (20 Pin) for optional Navigation System (AVIC-9DVD) (CD-RGB26P required for AVIC-90DVD)
AV-Bus Input
Auto Dimmer Control
AGLR (Anti-Glare, Low-Reflection) Coated LCD Color Screen
Detachable Face Security™ with Theft-Deterrent Flashing LED
MOSFET45 (45 W x 4-Channel High Power)
Two-Way Crossover
Front/Rear HPF & Subwoofer LPF
Sub-Out Level and Phase Control
XM Satellite Radio Ready
EEQ Performance Chip
3-band Parametric Equalizer
Easy EQ (EEQ) Switches 5 Factory, 1 User EQ Preset
Selectable Loudness Control
Selectable FIE (Front Image Enhancer)
Pioneer Virtual Graphic User Interface (GUI)
Supertuner®III™
IP-Bus System Control
A/V Inputs & Outputs
RCA Audio Preouts
Pioneer
Need to sell asap.
AV-Bus Input
Auto Dimmer Control
Two-Way Crossover
Supertuner®III™
RCA Audio Preouts
Pioneer
