1 - 10 of 10 Posts
Description: Selling leftover parts from a project car, GC8 swap
Location of seller:
Alberta, Canada
Willing to ship: Yes
Method of contact: PM
Price: PM me/accepting offers
Getting close to finishing project and need to clear up space. Keeping all these parts for a limited time and then will bring it to the junkyard. Get your parts while you can!
2.5RS parts -
Power steering pump/lines/pulley
Drive shaft, Rear CV axles
Front anti sway bar
5 speed transmission + support brace
Rear differential
Starter motor
Accelerator pedal
ECU
Cruise control
Radiator
Coolant overflow bottle
Hood scoop cover
Pitch stop
WRX parts -
Turbo engine cross member
Brake booster/master cylinder
Clutch master cylinder
Speedometer assembly
Power steering rack
AC Compressor/lines
Stock intercooler
TD04 turbocharger
Stock fuel injectors
Right rear ABS sensor
Flywheel
Power steering reservoir bracket
Cruise control
Transmission shift linkage
Pitch stop
Intake snorkel
SRS ecu
Steering column firewall rubber
Hood latch
Combination switches
Engine junction box
Windshield washer fluid bottle
Parking brake handle trim
Center HVAC vent trim
Power window switch panel - 94266 FE090
Ashtray
Fog, hazard, power mirror, cruise control, heated seat switches
Anyways how much would you do for the starter for a manual trans considering shipping might cost a bit more to ship from Canada to U.S.?
Super Moderator
2000 RSTi
The new forum software calls PM's "Conversations" now. So when you click on a person's name, look for "start conversations."
83582
Discussion Starter #8 (Edited)
I started one with you, thanks.
Shipping actually might not be too bad for smaller items, I shipped some stuff to California and Michigan and it was like $15-$20 on top of the item. I'm always open to reasonable offers as well.
Discussion Starter #10
1 - 10 of 10 Posts
