1 - 1 of 1 Posts
2004 STi PSM
Video, History & TONS of pic's can be found here
http://www.iwsti.com/forums/members-journals/130359-psm-04-sti-s-story-w-video-w-new-pic-s-9-17-elemet-tuning-inside.html
Tades, I'd love to get into a GC8 or GF8(swapped is a plus)
The Facts:
I recently replaced Brake,Tranny&Diff fluid, rotors, brake pads, tires, battery, header, Injectors, & Fuel Rails/lines/Regulator
Mileage: car has under 52k
Motor Build: done in July 07 with 33k(by Element Tuning)
Body: has 3 door dings(thanks to inconsiderate careless people), and one other not sure how to decribe it(not large maybe 2"), Bumper/hood also has some scratches and rock chips normal highway wear and something bounce'd up and hit me on the highway and took some paint with it on the passenger side of the bumper. The passenfer side door speaker is not working at the moment, also I have a factory 6 cd player radio in the car.
The Only thing I feel this car is missing is the upgraded fuel pump(which I have, just needs to be installed) and a tune, after that it will be another 500+whp car
Reason for the Sale: Wife is preggo and I need to cut some costs and the car is the biggest :bonk:
Power&performance
Engine Control:
Element Hydra Nemesis Engine management system
Wid ban 02
Launch Control
Flat Foot shifting
Motor:
CP Custom Spec Forged Race Pistons OEM Bore w/rings 9.5:1 compression
Element tuning rods
Cosworth camshafts 278/274
Cosworth Valves/spring/retainers
ARP Head studs
Element competition catch can
NGK 1 step colder spark plugs
Drivetrain:
Clutchmaster Stage 4 clutch
Turbo:
Element GT65 Turbocharger
Element Steel Braided Oil Line
Intake:
K&N Cone Filter
Element 4" inlet
Exhaust:
Perrin equal length Headers
Element rotated EWG up-pipe
Turbosmart Ultragate 38mm Waste gate
Element custom rotated Down Pipe
HKS Carbon Ti exhaust catback exhuast
Fuel delivery:
HydraMist Injection System(works directly through the ECU for a much better fail safe)
Ultimate Racing 1000cc Injectors
Ultimate Racing Fuel Rails
Aeromotive Fuel Pressure Regulator
Aeromotive custom fuel lines
Walbro Fuel pump(soon to be replaced with a Bosch 044)
JDM TGV deletes
Cooling:
Turbo XS Front Mount Intercooler
Turbosmart Raceport Blow Off Valve
Zerosports Thermostat
Koyo Radiator
GT Spec Radiator shroud
30% Tint
CF s202 Replica wing
CF seibon reverse hood scoop
Grill craft custom painted grill with Impreza "i" badge
2006 Custom Impreza Tail lights
Modified Headlights
Rally Armor Mud Flap
Sparco Pro 2000's
Sparco Custom Blue Inlay
Sparco Silver Harness bar
Sparco Silver 2"cam lock Harness
Sparco suede blue shoulder pads
Sparco Lap 5 Steering wheel/& boss
Sparco Steering wheel quick release
Defi Center Gauge Pod
Defi Control Unit
Defi 60mm Boost Gauge
Defi 60mm Oil Pressure Gauge
Defi 60mm EGT Gauge
Turbosmart EBoost2 Gauge
Autometer Dual Dash Gauge Pod
Aquamist Injection Flow Gauge
Stewart&Waner Gauge
Custom STi Floor Mats
Suspension&Handling
Megan Racing Track Coilovers
Cusco Front Strut bar
Greddy Rear Strut Bar
Agency Power Front EndLinks
Perrin Rear Endlinks
Perrin Front Sway Bar
Cusco Rear Sway Bar
Braking
DBA 5000 Slotted Front Rotors
DBA 4000 Slotted Rear Rotor
EBC Yellow Stuff Brake Pads
Agency Power Steel Brake lines
Wheels&Tires(newer tires)
Prodrive GC-05 17x8 +46
Rays Black Lugs
Kumo all seasons tires 235's
1 - 1 of 1 Posts
