I'm leaving for Iraq soon and I'd like to start with a new project when I return. This car is making well over 300hp at the wheels. I've run 12.1 @114 in it and Dominate the local autoX events.
Oh a side note the AC was deleted from this car.
Car is Located in Stratford NJ 08021
Specs:
Chassis has 138,000 miles on it.
Exterior:
V4 Front Bumper
STi Style hood scoop
Hella Supertones
STi Badge on Grill
Blacked out Ebay head lights
Painted amber stock corners
17inch SSR Comps.(225/45/R17 RT-615s)
Tinted windows front and rear(tint on rear windows is old and needs to be replaced but it's not too bad)
Both front fenders have knee dents for me working on the car and the passanger fender as a dent near the door. The rear bumper and above the tail light have small dents from some wood that fell on the car a few years back. It has normal door dings and a few scratches paint is not perfect but can look very nice with a nice detailing.
Interior:
Custom Made black leather/red stitching
Black JDM STi Legacy Shift knob
Center gauge pod with Autometer Oil Press, Oil Temp, Water Temp
Fuel Pressure gauge mounted on steering column. Boost and EGT on the Pillar
STi rear seats
Blitz Turbo Timer
Blitz SBC-ID boost controler
Black faced WRX 6 disc CD changer
Engine:
02 wrx engine(has less than 8,000 miles on it I just replaced it at the start of summer)
VF34 Turbo(Also very new I would say under 15,000 on the turbo)
JDM STi Topmount (& STi splitter)
TGV deletes
HKS turbo back
Perrin uppipe
DC sports Headers
Tail 38mm extrenal wastegate (dumped behind passanger axle)
Walbro 255lph Fuel Pump
STi pink Injectors
SPT Intake and heat shield
Koyo Radiator
Vishnu Crank pulley
Custom made boost activated water sprayer
Intake manifold is painted Red.
ECU: The car was Tuned by Chad Block at CBRD Speed factory in York PA. It has Launch control that is set at 5500rpm.
Suspension/Brakes/Transmission:
V4-5? STi 5spd Trans
Mechanical LSD rear Diff
Kartboy Short Shifter with bushings
ACT flywheel
ACT Street Clutch
Whiteline Steering Rack Bushings
Megan Racing coilovers(less than a year old)
Cusco 24mm rear sway bar
WRX wagon from sway bar
WRX front brakes (slotted rotors)
Hawk HPS pads in the front and Ferondo pads in the rear.
Specs:
Exterior:
V4 Front Bumper
Hella Supertones
STi Badge on Grill
Interior:
STi rear seats
Blitz Turbo Timer
Engine:
TGV deletes
HKS turbo back
Perrin uppipe
DC sports Headers
STi pink Injectors
Koyo Radiator
Vishnu Crank pulley
ACT flywheel
ACT Street Clutch
