1 - 8 of 8 Posts
93 version6 1.8L turbo 08 WRX
as the title says my front driver side brake caliper is sticking. ive tried replacing the caliper with a new one 3 times, replaced the brake proportioning valve, the master cylinder, bleed the brakes, bleed the master cylinder and im now out of ideas.
Super Moderator
2000 Slingshot RS-T (Sold)
The two replacement calipers are also sticking? What exactly are the symptoms.
99 Aspen White Coupe
Did you also replace the slide brackets for the pads, as well as the pads themselves? Properly grease the slides?
2005 STI , 1998 Outback Sport
did you replace the brake hose? If not try cracking the bleeder open, if the caliper frees up then its most likely the hose.
Discussion Starter · #6 ·
that might be the problem. it frees when the bleeder is opened. hmm ill try that
ok terrific.
'95 STi RA rep, rhd yo!
If you replaced a "sticking caliper" more than once, I can almost guarantee you need a new brake hose to that caliper.
Discussion Starter · #8 ·
tried
replaced the brake line. looked for pinched lines. i gave up and took it to the dealer.:curse:
1 - 8 of 8 Posts
