1 - 18 of 18 Posts
How hard would it be to move the stock front brakes to the rear? The reason I'm asking is because I am receiving stock WRX front brakes and new braided steel brake lines. It will also give me an opportunity to paint my calipers, without having my car out of service for a full day. Caution sign orange, here I come. :D
I've never worked on the rear brakes in the RS, but how different are they from the front? The emergency brake works by a drum, right? I have no idea where it is either.
Ok, in the engine compartment, I have two brake fluid reservoirs. How do they work? As in, which reservoir works which brakes?
Please help. :)
2000 Blue Ridge Pearl Subaru I
Not sure about the moving of front to back, but the reason you have two brake fluid cylinders in the engine bay is that one of them (the smaller one on the left) is the clutch master cylinder. The bigger one is for the brakes.
Scoobymods Guy
2010 Legacy 3.6R Limited
The rear brakes are very different than the fronts. The emergency brake dosen't clamp the caliper but there is a small set of brake shoes inside a drum that is part of the rotor I believe. So the rotors are different. Unless you want to do w/o an e-brake
The e-brake is all I use when I'm stopped.
So, to put different sized rotors on the back, i'll have to redo the e-brake? Sounds like too much work for an underskilled enthusiast. :)
Scoobymods Guy
Does your state have auto inspection? (we don't here in KS) most require a working e-brake. Chances are good that you will not have one after you do the swap. Just a watch out.
1 - 18 of 18 Posts
