21 - 27 of 27 Posts
Discussion Starter · #23 ·
oh yeh i rememeber do i need to reset my ecu by disconnecting the negative battery for 20 mins and then reconect it and leave it to idle for 10 mins for the check engine light because in youtube videos they said there ecu was giving out the code that air coming in wasnt in range and the temp wasnt in range so they said reset the ecu this way to make it forgot all the old settings.
Super Moderator
2000 RSTi
It can't hurt. I would also hold down on the brakes for a few seconds after the battery disconnects. The brake bulbs use up any remaining charge in the system.
Discussion Starter · #25 ·
So disconnect the battery run into the car and push down the brakes. Do i need to take my handbrake off or be in a specific gear or just push it down?
Super Moderator
2000 RSTi
Doesn't matter what gear you're in. Otherwise you got it.
21 - 27 of 27 Posts
